Importing PCB from Eagle
daniel_haber
Member Posts: 3 ✭
Hi, I've created a PCB in Eagle and would like to export it from Eagle and then import it into OnShape so I can design a box for it. I can't find a way to do this. There seems to be an old app IDF-to-3D that no longer exists that would have done this, but I don't think it exists anymore.
OptionsMarc_Miller Member Posts: 110 ✭✭✭@daniel_haber What version of Eagle are you using? I'm using 9.2.2 at the moment and when viewing the BRD, under File -> Export, there is a STEP option.
Then once it finishes, you'll find the STEP file in the "Home" area of the Eagle Control Panel. Click on that to save it somewhere so you can import it into Onshape.
It looks a bit funny how it represents component placement, but the actual PCB is there and seems like it would be fairly useful for making a case around it and mounting points. If your board has knobs/jacks/etc coming off it, not having those visualized will make it harder to know exactly where holes in the case should go though.
top of board:
bottom view, which shows my mounting holes so that would be useful.
I'm not sure if any of this would help you though @owen_sparks for milling traces, but might be useful for designing cases.
7
top of board:
