[New] Fill gaps FeatureScript
TimRice
Member, Moderator, Onshape Employees Posts: 315
Easily identify open gaps in surface bodies with this new custom feature with option to automatically fill the gaps and create a solid part.
https://cad.onshape.com/documents/ce40596b860ab50d657e1a25/v/93eddbbe03dde1a35dcb3d19/e/c40a2b405f618e4760ef6ebb
Thanks to @kevin_o_toole_1 and a few others for the guidance!
Onshape, Inc.
Onshape, Inc.
Thanks Owen.
That was sort of the intent for this feature but keep in mind a broken edge may still prevent the fill from solving. If you have an import that could be made public (or shared with me) I would love to take a try at it
Onshape, Inc.
Any way to choose two surface or more bodies? I have surfaces that look OK to work for 'Enclose' but fail. Seems your routine would be just the thing!
Thanks!
Onshape, Inc.
