Estes Rocket Challenge
david_kurtz
                    Member Posts: 24 EDU
                    This project has students use OnShape to design model rockets.  We 3D print completed rockets and launch them.
I have students to their initial rocket designs using OpenRocket. This free software is easy to use and helps students make aerodynamically stable rockets.
I have students work alone if we have small class sizes. If we have a large class, I have student work with a partner. In this case, I have each student design every other part (student A makes the bottom tube, B makes the fins and top tube, A makes the Nose cone). This requires the students to coordinate their designs and takes advantage of OnShape's usefulness as a collaborative design platform.
Students must peer-review one another's designs before projects are 3D printed. This involves checking the drawing files to see that all parts will fit and that the design is ready to go into production. In the event that a rocket does not assemble correctly after 3D printing, I give the students a pair of calipers, the 3D printed parts and the drawing files. They then need to check to see if the problem is a result of poor design or poor manufacturing.
