Can I import a vector PDF into OS such that I can use the geometry
SledDriver
Member Posts: 117 ✭✭✭
I have an accurate vector 2D PDF file which I wish to get into a sketch within a part studio for further cad development.
Is this possible.
Help and Google have failed me so far.
I can get the pdf artwork imported into OS just fine as its own entity, but I can't see how I can then move that geometry into a part studio sketch without manually tracing over it?
Is this possible.
If you can use some other software (possibly illustrator) to export the vector lines to .dxf you maybe get it in.5
OK, ta. I converted to DXF and that worked fine. Just expected to be able to import PDF vector...0
