See https://forum.onshape.com/discussion/11786/new-fs-set-color-also-ral-color/p1?new=1
https://cad.onshape.com/documents/e93dd3392eec43195d591a42/w/64c8672743aee6964cc558b2/e/849a3498fd1fdae38783be30
I've been busy with grad school recently, so no further updates have actually happened. Since the documents themselves are the repo, I've been leaving change notes in the properties of each version, as well as at the top of the FeatureScript code.
Great job - I love this feature script! THANK YOU for your contribution.
This saved me hours of clicking in assembly mode. And, if I change my design, hours more again.
Onshape should pick this up and make it a supported feature with a more efficient and (yes, computationally intense layout algorithm). You'll see below how much time I saved, and that likely you could stack everything into 5 sheets instead of the 6 required.
