Sketch toolbar doesn't show sketch tools
On my (late 2011High Sierra, Safari) MacBook, when I start a new sketch the toolbar initially shows sketch tools as per the Training vid but when I click the Green check in the Select Sketch Plane box the toolbar reverts to modelling tools (extrusion etc).
Anyone else seeing this?
I'll try with Chrome browser next...
KatieHuffman Member, Onshape Employees, Developers Posts: 190
When you click the green checkmark in the sketch dialog, you are accepting the sketch- and therefore leaving it. Don't accept the sketch until you have completed sketching.5
Also I suspect I cannot do a single 3D master 'General Assembly sketch, e.g. to set out all the important reference points that all the subassemblies' parts need to align to (or avoid), like external mounting bolts, pipes, ventilation slots or casing?
Can I do an XZ sketch then a YZ sketch with the XZ showing for alignment purposes?
