Select axis to revolve around
darren_mason871
Member Posts: 35 ✭
I'm trying to revolve this shape. I made a construction line but can't select it as an axis.
bruce_williams Member, Developers Posts: 842 PROWorks for me. In dialog box select Revolve axis and then the geometry.www.accuratepattern.com1
You have a few things going on here.
1) as stated above you will need a non-intersecting shape
2) the solid tools (extrude, sweep, revolve, loft) require a sketch region (closed & shaded) that means all the curves defining region will need to be on one sketch
3) you used a 3D spline - that will not work directly for making the sketch region. You can use a standard sketch spline OR the Use command to transfer the spline to the region sketch
edit: I should add - revolve is tricky to get all the requirements at first. It is pretty easy once you practice a few and see how it works.
