Fillet a corner of 2 lines on different planes
darren_mason871
Member Posts: 35 ✭
Can the fillet tool be used on this middle corner at intersecting planes? Sketch 1 and Sketch 2
steve_shubin Member Posts: 1,066 ✭✭✭✭
Using the 3D Fillet FeatureScript that @MBartlett21 left a link to, and then using the Pipe FeatureScript, well here’s how it all works
2
https://cad.onshape.com/documents/b623e62012d50f8c31e5d157/w/e632a16baaf38b255b5e29f3/e/70b71176aa90fa7c762ec9f8
Or in that same doc you can see an example of use of a custom feature that takes a bunch of points and radii and creates a line-arc-line chain. If what you are after is a line-arc chain then that could be a simpler way to capture the creation. The custom feature is defined in this doc:
https://cad.onshape.com/documents/ca7d35ff68a48d0ee7e2be9b/w/82356f23c3209a32074dfb89/e/c9925e1130e8f87ab2b3f246
TVP, Onshape R&D
https://cad.onshape.com/documents/f2142f9b0b8676a357bed10e/w/5bfb4561275b308a9eb79a04/e/7e10f2f37cf15b4969fb50d6
https://cad.onshape.com/documents/5d235ff0a55e76d384b9e1a4
@darren_mason871
