Sheet Metal Cut in Flat Pattern
kent_hendersonkent_henderson Member Posts: 71 PRO
https://cad.onshape.com/documents/6a4442aa4be150f4df289717/w/bc65d5e9efeea47402c31a16/e/95dd8a5c8b697a68adcc6b75
Take a look at the attached document. I have a series of 6 holes that when the extrude is unsupressed, the flat pattern breaks. These are cuts in the flat pattern. It seems if the edge of a flat pattern cut lands on the bend radius the flat pattern breaks. These holes are 0.425 Ø If I change to 0.25 or 1.00 everything is fine. Is this a bug?
