O-ring Groove Custom Feature
TimRice
Member, Moderator, Onshape Employees Posts: 315
With the recent release of O-rings in standard content I created a custom feature for adding the o-ring grooves to your parts! Add a radial or axial groove and the feature will autosize to match the geometry. A mate connector is also added for easy mating in assemblies.
Add it here: https://cad.onshape.com/documents/7cc7800afe750c5b8148b440/v/ae1c45a09a12e8ffab98ad28/e/a9662007830c2b8be9ec314b
Onshape, Inc.
Onshape, Inc.
5
Onshape, Inc.
https://www.applerubber.com/src/pdf/seal-design-guide.pdf
https://www.parker.com/Literature/O-Ring%20Division%20Literature/ORD%205700.pdf
Onshape, Inc.
The center of the circles are coincident with the origin. And the mate connector is placed at the center of the cylinder. Yet I get this message that the mate connector does not fall on the central axis of the cylinder
What am I doing wrong ?https://cad.onshape.com/documents/e462cedb36a36ad82966c34f/w/c730f2e9b8a481b6d46991d4/e/29fcfe7e47c59da9a2624bf1
Fixed! Please update your linked version of the featurescript and it will work as expected. Thank you for bringing this to my attention!
Onshape, Inc.
Thanks for taking care of this, and for the prompt response.
I really like your FeatureScript !
https://cad.onshape.com/documents/7cc7800afe750c5b8148b440/v/c58e67397ca93b257ec82b12/e/5cb14a47504b827b1f1b26c0
Onshape, Inc.
