Default offset & fillet dimensions
josh_deetz
PRO
I often try to do an offset, and get the message "Offset cannot be created at this distance". But the problem is I cannot get to the point where I can actually change the dimension because the default dimension is unresolvable, so I cannot 'place' the offset and change the dimension. (Doing a reverse offset and then changing the dimension to be negative sometimes flips it back, but sometimes it cannot resolve either direction.)
Fillet in sketches has the same issue. I have a 1x1 cube, add a fillet, but it defaults to 5, so it cannot solve.
Is there a way to change the default values, or a way to change the dimension before 'placing' the offset or fillet? I've tried everything, to no avail.
Grab the handle and drag the fillet into possible range, then add exact value.
Default values cannot be edited at the moment.//rami2
Default values cannot be edited at the moment.//rami2 -
Thank you very much! I have clicked that handle hundreds of times, never thought to click and drag.1
Same happened to me few years back
//rami1 -
#Metoo3dcad said:Same happened to me few years back
HWM-Water Ltd0 -
How do you change direction of offset after accepting it? tried a negative number and nothing
