Default offset & fillet dimensions
I often try to do an offset, and get the message "Offset cannot be created at this distance". But the problem is I cannot get to the point where I can actually change the dimension because the default dimension is unresolvable, so I cannot 'place' the offset and change the dimension. (Doing a reverse offset and then changing the dimension to be negative sometimes flips it back, but sometimes it cannot resolve either direction.)
Fillet in sketches has the same issue. I have a 1x1 cube, add a fillet, but it defaults to 5, so it cannot solve.
Is there a way to change the default values, or a way to change the dimension before 'placing' the offset or fillet? I've tried everything, to no avail.
  • 3dcad
    3dcad Posts: 2,482 PRO
    edited October 2019 Answer ✓
    Grab the handle and drag the fillet into possible range, then add exact value.
    Default values cannot be edited at the moment.
  • 3dcad
  • josh_deetz
    josh_deetz Posts: 4 PRO
    Thank you very much! I have clicked that handle hundreds of times, never thought to click and drag.
  • 3dcad
    Same happened to me few years back =)
  • owen_sparks
    owen_sparks Posts: 2,660 PRO
    #Metoo
  • Terry_Thom
    Terry_Thom Posts: 2 PRO
    How do you change direction of offset after accepting it?  tried a negative number and nothing
  • @Terry_Thom
    works to change dimension to negative for me
    www.accuratepattern.com
