perpective views in drawings
martin_streat
Member Posts: 2 ✭
Hi is it possible to make the isometric view on a drawing sheet into a perspective view?
I don't think it's possible and thinking the history & use of drawings I wouldn't expect such improvement anytime soon.
You didn't mention why you need such drawing but there is workaround, in modeling space select 'hidden edges removed' from small view cube:
You can then take a screenshot and insert that image into drawing - a bit hassle and image needs to be manually updated if model changes but for occassional use it does the job.
//rami6
//rami6 -
Vote Up the "drawing perspective view" feature here: https://forum.onshape.com/discussion/10304
What would also be nice to have is to be able to export a DXF from that perspective view directly from the 3D environment. The DXF result would be just a flat view but means that it would be vector lines and not an image. This is useful when importing DXF into Illustrator for writing up technical manuals for example.0
