Shell Error under 5mm
I would like to reduce the thickness of this part from 5mm to 2.5mm. However, when I edit the shell, the part can not regenerate correctly. Any thought on what the problem is? Thanks! https://cad.onshape.com/documents/5f3931165338df06ff76350c/w/e489c8be29debbe1e7cddeeb/e/74512c9dc9dd2af2adbbf35e
  • Jarett_Elser
    Jarett_Elser Member Posts: 2
    @matthew_stacy Thank you for the suggestion! Simplifying the profile did help to solve this shell thickness problem.
