how can I change the default offset value in sketch?
C_D_R
Member Posts: 5 PRO
My offset always defaults to 5(mm) which is often too large for the features I am working with and will cause a failure before I can choose an appropriate value.
NeilCooke Moderator, Onshape Employees Posts: 5,308Click and drag to create values other than 5mmSenior Director, Technical Services, EMEAI6
And you can select a number of lines to offset using one numeric input
