Flatten a sheet metal cone shape
Everything I see is strict cylinder. Does anyone have a work around to be able to produce a sheet metal flat pattern?
  • wayne_sauderwayne_sauder Member, csevp Posts: 477 PRO
    I have done it a few times using step bends. That does not produce a true round but it has produced some nice cones that work in my applications. If you need to have a rolled cone and dimensions are critical then that will not work and I have not found a workaround yet.
  • romeograhamromeograham Member, csevp Posts: 657 PRO
    The FeatureScript General Cone Unfold works well: https://cad.onshape.com/documents/0bb13c1b6ed6d4a6dd75cf99/v/54a1492241fd6e87c631683f/e/f0e6783ee0f9a81dab9e0dab
    Go to that document, and click the + Custom Features button:
    Then you can use the custom FeatureScript in your document. There is an example of how to use it in one of the Part Studios.
    Once you have a flat sketch of the unfolded cone (which the FeatureScript will produce) you can then use Sheet Metal tools to make it a flat pattern. You don't get the typical Sheet Metal ability to fold / unfold etc, but you can at least get a Sheet Metal part that is a Flat Pattern of your conical shape.
