Project to Surface
Stuart_Tod
Stuart_Tod Member Posts: 65 PRO
I've used the search function in the hope of finding an answer, but without any luck. So, can I project a 2-D sketch onto an underlying (curved) surface to provide a 3-D 'path'?
I'm trying to project sketch 5 in this open document onto the curved surface of Part 1 ( https://cad.onshape.com/documents/ef2e97eee4cf47578ba6a15d/w/d3c8a9e635194cf19de53fae )
And, if we can, when are we going to get a 'path' mate to go with the others? Please!
Stuart
  • Stuart_Tod
    Nico,
    Thanks - will have to hope this is on the OS wish list, and somewhere near the top (along with 'Path Mate' !
    Stuart
  • andrew_troup
    andrew_troup Member, Mentor Posts: 1,585 ✭✭✭✭✭
    edited May 2015
    There are a number of workarounds, though. The only ones which spring immediately to mind are powerful, rather than pretty ...
    One possibility:  use same sketches which created the "curved surface" you refer to in your post to make dummy target solid. Now extrude your "2-D sketch" as a surface, use that surface to split the dummy solid, use resulting edges as 3D curves, hide dummy solid (I said it wasn't pretty) ...
  • Stuart_Tod
    Andrew,
    .......it's five o'clock on a Friday afternoon here....I think my head just exploded halfway through your workaround. That'll be something for me to try on Monday!
    Thanks
    Stuart
  • andrew_troup
    edited May 2015
    Stuart
    That's nothing, it's 0400 Saturday morning here (don't ask!)
    I shared a model I was looking at for Raino, I hacked it to do a quick proof of concept (not as ugly in practice as my description made it sound)
     it's called "Loft testing - Raino" and the tab which demonstrates the workaround is called "Project Sketch to Solid" The last two features constitute the workaround.
  • nav
    nav Member Posts: 258 ✭✭✭✭
    Hi @stuart_tod I was testing a little bit more not sure if it's the same method proposed by @andrew_troup as I did not have to split the part. I basically drew a cylinder, then in an offset plane I drew the curve I wanted to project, I used surface Extrusion Up to Next and in the intersection of both it creates the projected curve, in the intersection plane of the curve and the plane I drew the sketch to sweep (Used the pierced constraint). Below the sequence of images, hope it helps.
    Nico
    1.png 189.8K
    2.png 319.9K
    3.png 232.1K
    4.png 221.4K
    Nicolas Ariza V.
  • andrew_troup
    I can't think of a single thing about my method I like as much as everything about @nav's
  • zachary_widbin
    zachary_widbin Member Posts: 1 EDU
    @nav, I lose you on the last two pictures. Would you mind sharing that document? Thanks.
  • mahir
    mahir Member, Developers Posts: 1,324 ✭✭✭✭✭
    @zachary_widbin, in pic 2 @nav created a circular profile sketch on a plane normal to the curve on the cylinder. In pic 3 he generated a swept solid using that circular profile and curved path. In pic 4 he deletes the construction surface.
  • famadorian
    famadorian Member Posts: 390 ✭✭✭
    Andrew,
    Thanks
    Stuart
    really funny that I'm reading this five o'clock on a friday afternoon (UTC+1), three years later;)
    Anyways, projecting a spline onto a surface; has that gotten anywhere?
  • konstantin_shiriazdanov
    which type of projection you need? along direction, to the closest point, from a pole point, from a pole line?
  • tim_brotherhood
    tim_brotherhood Member Posts: 2 EDU
    Any news on this being added to Onshape?
