Convenient tool / method for creating "tabs" (NOT sheet metal)
This part is meant to be screwed into a wall so I need some "wings" or "flaps" to extend outward (from the highlighted edge).
The naive way would be just to create a new drawing on the face, [u]se the bottom edge, and then extrude and thicken it. Then repeat that whole process for the opposite side, or mirror the resulting part. I'd love to do this without having to create a drawing just so I can extrude an edge that is already defined in some other geometry. Is there such another clever way of accomplishing this?
@tom_auger
Onshape lets you reuse sketch so you can have the tab shapes on your original sketch and Extrude Symmetric or Up to face with offset and the other end with Second end position.www.accuratepattern.com5 -
@tom_auger
YOU SAID — I'd love to do this without having to create a drawing just so I can extrude an edge that is already defined in some other geometry.
OK I’m assuming when you said without creating a drawing, that you actually meant - without creating a sketch.
You can create a flange by extruding an edge with thickness, using something called Thin-feature.
5
@tom_auger
The only thing naive about your approach is creating a sketch, then surface, just to thicken...
If you are making a solid, just stick to solid modeling techniques until they "can't" do what you need.
That being said:
select the face
create a sketch (shift+s)
draw a rectangle (g)
click one corner of the box
click the opposite edge
set a dim
extrude (new) -> set length
Mirror (Part) -> (Add)
Or you could sketch on the Front face of the part (the long face in my example) and draw two squares and make them equal length on each end.
There is absolutely nothing wrong with either approach. It seems like a lot of steps but, sketch/extrude is the bread and butter of solid modeling. It just becomes quicker with practice.
For solid modeling, only use surfaces if they shape is "funky"... or you need some sort of re-usable geometry to reference many features.
edit: forgot to attach the gif...
2 -
@tom_auger
5 -
@tom_auger
YOU SAID — Is there such another clever way of accomplishing this ?
Here’s a way that’s more than twice as fast as using the Thin-feature extrude method
1 -
steve_shubin that is EXACTLY what I was looking for! Thank you0
steve_shubin said:@tom_auger
> The screen capture is moving a bit fast and I'm not used to the mobile UI - in this example are you just creating a new sketch on the bottom face and then drawing a rectangle on it and extruding that? If so - are the two sketched "linked' in any way such that if the dimensions of the first sketch change (say the width of the box) then the second sketch will also scale its width (like when you Use an entity)?0 -
@tom_auger
YOU ASKED — are you just creating a new sketch on the bottom face and then drawing a rectangle on it and extruding that?
ANSWER IS YES
YOU ALSO ASKED — If so - are the two sketches "linked' in any way such that if the dimensions of the first sketch change (say the width of the box), then the second sketch will also?
AGAIN, YES
Sketch 2 automatically added in constraints that linked it to the box (the extruded Sketch 1). Then as Sketch 2 was extruded, those flanges became one with the box as the extrusion defaulted to ADD.
