Can't boolean?
Hey guys, I can't get this to Boolean, any ideas why?
clayton_ertley Member Posts: 58 ✭✭
I made a private copy and tried to do a union with no success. If I had to guess I would say it is because of the geometry shown in the picture I have attached.
If you could fix that and try, It may work. Other than that, you will need to wait until an OnShape employee answers.
5 -
Were you trying to union. If so, what for? It looks like some kind of cell phone cover.
If you are going to get it printed, you will likely need to cut some holes in the hollow areas. if the printer to be used uses support materials (i think you can get away with it using FDM)
I didn't notice anything to gain from a subtraction. Please advise.
5
If it was a link to a model make sure it is public.
https://cad.onshape.com/documents/30a36e1cbcc740668d747e84/w/d501b5ef4c4e4745bc6533c5/e/eb06b400bff648119c5d8271
I looked at the model again and I see the boolean worked. I see that I was wrong about what it was. May I ask what it is?
Good luck with your design.
P.S I know how you feel about the printer! My wife and I are saving for a Formlabs SLS printer. I can't wait!
I made a private copy of your model and began looking at some of your construction methods. I noticed in sketch 1 splines were used. However, the end conditions were not constrained adequately. Have a look at the screenshot I took. I'd say cleaning up such conditions that may exist throughout the model will help significantly. - I'll be happy to share other modeling practices if you want to continue the discussion.
Creative and Technical Skill Development Coach
Design Inspiration
LinkedIn Bio
Community based 3D printing services.
