Convex surface
andrew_morris929
Member Posts: 2 ✭
Hi,
New to onShape, and enjoying it so far, but I have a question which may be really easy
Is the an easy way to apply a convex surface onto on side of a cube for example?
I'm trying to reproduce a panel that's about 5mm thick, with a slight convex surface, about 2mm deep.
I though maybe of somehow intersecting a rectangular block with a large sphere, as that's how I'd do it in OpenSCAD, but is there a neater solution?
Thanks in advance
Thanks in advance
YOU SAID —
... a convex surface onto on side of a CUBE. I'm trying to reproduce a panel that's about 5mm THICK, with a slight convex surface, about 2mm DEEP.
Little hard for me to interpret what you said above. I’m guessing you wanted a cube that was 5mm in all dimensions
And I’m guessing the 2mm was from the top to the bottom of the curve.
Anyway here’s what I came up with — it’s just one more way of doing it
By the way, the last feature — REVOLVE — was set to REMOVE
Here’s a way that is more along the lines of what you and @john_mcclary mentioned above
When doing the Extrude — Intersection was used
https://cad.onshape.com/documents/05c525440bb10fdeb56acd74/w/f986f1da14f6bbce9b41ea8c/e/93b3b6b8af3f1a1818936453
I stand corrected
Like I said in my first post, I did see where he said SLIGHT, but it’s hard for me to interpret what he meant by the 2mm and the 5mm dimensions
And where the CUBE came into play ?
Yeah I think you’re right John. Because I went back and read it again and it said PANEL
AND this time I took your lead and incorporated SLIGHT
