Importing filea
hi all
new to onshape. i have a couple of questions
1. can sketchup files be imported?
2. how to import files (onshape) from other projects not the current one
thanks andrew
thanks andrew
cyclonewade OS Professional, Mentor, Developers Posts: 53 ✭✭✭
Welcome @andrew_2
Sketchup files will need to be translated into Parasolid, ACIS, STEP, IGES, CATIA v5, SolidWorks, Inventor, Pro/E, Creo or JT format to bring into Onshape.
You can right click on any "Part Studio" tab and select "Copy to Clipboard". In the destination document select the "plus" sign and choose "Paste Tab". This will copy the studio from one document to another. Onshape is working on allowing referencing between documents so not to duplicate geometry, but this feature is not currently available so you are left with copying.
Cheers!
W.imagine.create.deliver5
Cheers!
W.
