How to find the id of several bodies in "Query" with several mouse Picks
Fda
Posts: 42 ✭✭
I am trying to pass the body id to rename solids with a string + i (1,2,3 ...... etc)
annotation { "Feature Type Name" : "Name my_Part" }
export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
precondition
// Define the parameters of the feature type
annotation { "Name" : "Nome", "Default" : "Part_" }
definition.Name_Part is string;
annotation { "Name" : "My Query", "Filter" : EntityType.BODY, "MaxNumberOfPicks" : 20 }
definition.parts is Query;
// Define the function's action
var myString = definition.Name_Part;
var parts is array = evaluateQuery(context, definition.parts);
//println(parts[1]);
for (var i = 0; i < size(definition.Name_Part); i += 1)
//println(someString~i);
setProperty(context, {
"entities" : definition.parts,
"propertyType" : PropertyType.NAME,
"value" : myString ~ i
ups, sorry. this works
for (var i = 0; i < size(parts); i += 1)<br> {<br><br> //println(someString~i);<br> setProperty(context, {<br> "entities" : parts[i],<br> "propertyType" : PropertyType.NAME,<br> "value" : myString ~ i<br> });<br><br><br> }
5
for (var i = 0; i < size(definition.Name_Part); i += 1) {this should work, but you may need to reset part studio properties first, if you renamed parts manually.
setProperty(context, { "entities" : parts[i], "propertyType" : PropertyType.NAME, "value" : myString ~ i });
1 -
Thanks konstantin_shiriazdanov, but it doesn't work.I need to find a way to go to
"entities":
The id one of each "body"But I am somewhat lost.konstantin_shiriazdanov said:for (var i = 0; i < size(definition.Name_Part); i += 1) {this should work, but you may need to reset part studio properties first, if you renamed parts manually.
5 -
This code works
Thanks konstantin_shiriazdanovI leave it in the forum in case someone can help you.annotation { "Feature Type Name" : "Name myPart" } export const myFeature = defineFeature(function(context is Context, id is Id, definition is map) precondition { // Define the parameters of the feature type annotation { "Name" : "Nome", "Default" : "Part_" } definition.Name_Part is string; annotation { "Name" : "My Query", "Filter" : EntityType.BODY} definition.parts is Query; } { // Define the function's action var myString = definition.Name_Part; var parts is array = evaluateQuery(context, definition.parts); for (var i = 0; i < size(parts); i += 1) { setProperty(context, { "entities" :parts[i], "propertyType" : PropertyType.NAME, "value" : myString ~ i }); } });
