How to find the id of several bodies in "Query" with several mouse Picks
Fda
Fda Member Posts: 42 ✭✭
I am trying to pass the body id to rename solids with a string + i (1,2,3 ...... etc)
annotation { "Feature Type Name" : "Name my_Part" }
export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        // Define the parameters of the feature type
        annotation { "Name" : "Nome", "Default" : "Part_" }
        definition.Name_Part  is string;
        annotation { "Name" : "My Query", "Filter" : EntityType.BODY, "MaxNumberOfPicks" : 20 }
        definition.parts is Query;
        // Define the function's action
        var myString = definition.Name_Part;
        var parts is array = evaluateQuery(context, definition.parts);
        //println(parts[1]);
        for (var i = 0; i < size(definition.Name_Part); i += 1)
            //println(someString~i);
            setProperty(context, {
                        "entities" : definition.parts,
                        "propertyType" : PropertyType.NAME,
                        "value" : myString ~ i
  • konstantin_shiriazdanov
    edited March 2020
    setProperty(context, { "entities" : parts[i], "propertyType" : PropertyType.NAME, "value" : myString ~ i });
    this should work, but you may need to reset part studio properties first, if you renamed parts manually.
  • Fda
    Thanks konstantin_shiriazdanov, but it doesn't work.
    I need to find a way to go to
     "entities":
    The id one of each "body"
    But I am somewhat lost.
  • Fda
    This code works :)
    I leave it in the forum in case someone can help you.
    annotation { "Feature Type Name" : "Name myPart" }
        precondition
            annotation { "Name" : "My Query", "Filter" : EntityType.BODY}
            for (var i = 0; i < size(parts); i += 1)
                            "entities" :parts[i],
