Fixing invalid iges import - identifying faulty topology
stephen_allen
stephen_allen Member Posts: 19 ✭
edited April 2020 in Community Support
Morning all,
Overall, I'm trying to achieve something very simple here - make some holes bigger in a part called TGuardW2_v2 - however the part is invalid, and I think I'm missing something because the various "fix" tutorials are not helping.
I am working in this document. TGuardW2_v2 is an imported iges part which I created in FreeCad from an stl mesh (because OS can't generate a part from an stl mesh). There were no errors in FreeCad for either the mesh or the part.
I can see there are two surfaces of TGuardW2_v2 that OS doesn't like (faulty topology) - unfortunately, one of these is the main surface of the part (the imported TriggerW1_v2 has the same problem, but the main surface is not broken, so I can happily derive a part from that).
I've tried:
  • Deriving a part avoiding the faulty surfaces - unfortunately the main surface has faulty topology.
  • Using a boolean operation to "mould" the part (as per another "fix" thread) - cannot use a composite part.
  • Using the inbuilt "highlight boundary edges"  - nothing shows up.
  • Using the"find laminar edges" featurescript from another thread - nothing shows up.
  • Looking through with section view - no red edges.
I think I may be fundamentally misunderstanding what I am trying to acheive with a "fix"?
  • stephen_allen
    I saw Boolean Plus, but noted difficulties with edges of circles - in any event I've obtained a STEP file from the original designer - so this discussion is academic. Thanks again @NeilCooke for your help
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,103 image
    Hi @stephen_allen - there doesn't appear to be any holes in Surface1 - the faulty topology is probably overlapping edges/surfaces or inverted surface normals - this is kind of expected from IGES and/or STL. Can I ask what the purpose of this project is? Where did the original geometry come from? Mesh geometry in Onshape is only intended to be used as a modeling reference, not for making solids. Can you not achieve what you want to do in FreeCAD?
  • stephen_allen
    @NeilCooke The project is remixing a community-source foam dart (nerf) blaster to use (mostly) printable hardware (I, and others are UK based so cannot easily access the US tubing and screws required). A tiny bit more info is here:
    All the project now needs is me making the machine-screw holes in TGuardW2_v2 big enough to take a sturdy (4mm-ish) printed interference-fit hex plug. I've successfully done this (where applicable) for the other 10 parts which successfully imported as iges files.
    Maybe "holes" is the incorrect technical terminology - what I mean are arrowed in the (crudely-made) picture.
    Unfortunately I cannot achieve what I want in FreeCad without re-learning the package - this is because the UI in the latest version is unfathomable. I used to be quite proficient in FreeCad, but now cannot even do simple things like boolean operations / simple sketches pads and cuts, as there are multiple new preconditions (including an new entity called an object) which have been added the workflow that I don't yet understand.
    Perhaps it is easier for me to reverse engineer (trace) the part in OS, than (1) re-learn FreeCad; (2) fix the part; or (3) or contact the originator for a CAD version.
    I am probably slightly hampered by being a hobbyist who only has access to a linux box, and no professional CAD packages.
  • NeilCooke
    Nothing wrong with Linux - works perfectly with Onshape :smile:
    Probably easier to try and model around it. There are other solutions you could possibly try, but the part looks simple enough to remodel and it’s probably faster.
  • stephen_allen
    Linux for the win :smile:
    Thanks for your help - unless any other ideas come up, I'll either remodel, or edit the mesh directly in Blender - I understand that Blender has basic boolean functionality, which might help
  • NeilCooke
    There is a custom feature called Boolean Plus (see + icon far right in Part Studio) that can Boolean meshes and solids. You could perhaps model the hole as a solid and subtract it from the mesh using that.
  • stephen_allen
