Rest api haw i can import stl file in document
Sergei_krasovskii
Member Posts: 3 PRO
Upload File to New Blob Element not work please help
Hi @Sergei_krasovskii,
The Upload File to New Blob Element is the right endpoint to use. Which programming language are you using? And in what way doesn't it work? Are you getting an error? If using the Python client, you can see an example of a passing test that uploads stl here: https://github.com/onshape-public/onshape-clients/blob/next/python/test/test_import.py#L7 .
I use api explorer for test and if i try Upload File to New Blob Element request no answer.
And another question is how to put a document in a folder0
