opBoolean.SUBTRACTION not working?
Federico_Casarini
Federico_Casarini Member Posts: 9 PRO
Hello! I am trying to create a quick feature script to engrave a text onto an existing object. This is the code I am using:
annotation { "Feature Type Name" : "Tag" }
export const Tag = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
    annotation { "Name" : "Location and Orientation", "Filter" : BodyType.MATE_CONNECTOR, "MaxNumberOfPicks" : 1 }
    definition.direction is Query;
    annotation { "Name" : "Name", "Default" : "Name" }
    definition.myString is string;
    annotation { "Name" : "Size[mm]:" }
    isReal(definition.textsize, TAG_BOUNDS);
    var sketch_tag = newSketchOnPlane(context, id + "sketch11", {
            "sketchPlane" : plane(WORLD_COORD_SYSTEM)
    skText(sketch_tag, "text1", {
            "text" : definition.myString,
            "construction": true,
            "fontName" : "OpenSans-Regular.ttf",
            "firstCorner" : vector(1,0.1) * millimeter ,
            "secondCorner" : vector(0.25,definition.textsize) * millimeter
    skSolve(sketch_tag);
            extrude(context, id + "extrude21", {
            "entities" : qSketchRegion(id + "sketch11",true),
            "endBound" : BoundingType.BLIND,
            "depth" : -0.5 * millimeter
   //delete the sketch
   opDeleteBodies(context, id + "deleteBodies", { "entities" : qCreatedBy(id + "sketch11") });
    var dir = definition.direction;
    var direction = evMateConnector(context, { "mateConnector" : dir });
    var start = direction.origin;  // xyz
    const moveFrom = coordSystem(vector(0, 0, 0) * millimeter, vector(1, 0, 0), vector(0, 0, 1));
    const moveTo = coordSystem( start, direction.xAxis, direction.zAxis );  // (origin * units, xAxis, zAxis)
    opTransform(context, id + "transform1", {
            "bodies" : qCreatedBy(id + "extrude21", EntityType.BODY),
            "transform" : toWorld(moveTo) * fromWorld(moveFrom)
    var target = qSubtraction(qBodyType(qEverything(EntityType.BODY), BodyType.SOLID), qCreatedBy(id + "extrude21", EntityType.BODY));
    opBoolean(context, id + "boolean21", {
             "tools" : qBodyType(qCreatedBy(id + "extrude21", EntityType.BODY), BodyType.SOLID),
             "target" :target,
             "operationType" : BooleanOperationType.SUBTRACTION,
             "keepTools": false
    debug(context, target);
    debug(context, qBodyType(qCreatedBy(id + "extrude21", EntityType.BODY), BodyType.SOLID));
The idea is to create a sketch on the top plane, extrude it, move it onto the selected plane through the mate connector and subtract the text from the original solid. Unfortunately, when I run the code, I get a "cannot resolve entities" error. The tools and target are intersecting each other.
I also added a debug line to check if I was selecting the right solids and seems correct.
Can anyone help me with this?
Thanks!
Fed
  • Federico_Casarini
    Hi Jake, thanks for the help! Sorry it's the first time I post on the forum, I will create a code box next time.
    You are absolutely right, that worked! I guess that anything that is inside the "quotes" doesn't generate an error in the editor.
    Thanks a lot!
    Fed
  • Federico_Casarini
    Yes! If the error at runtime could point at which line went wrong, it will certainly help the newbies like me! :) thanks again!
  • NeilCooke
    @Federico_Casarini - it does. If you open the FeatureScript Notices panel (the checkmark in curly braces at the top), it will give you a stack trace as to where the error lies.
  • Federico_Casarini
    Hi Neil, thanks for this! I was referring to the actual line that generates the error. Something like "targets is undefined" could be helpful. I appreciate it's the kind of error that you do only once, because now I know what to look for. But it might save some time to new starters.
    Thanks for all you help, super appreciated. You guys are doing a great job!
    Fed
