How can I get help with Kirimoto? Worked a couple a few times now it won't let me slice. All very cl
bruce_sutherland
Member Posts: 5 EDU
How can I get help with Kirimoto? Worked a couple a few times but now it won't let me slice. Says no processes selected.
All very clunky.
All very clunky.
I just want to use the Kirimoto for my high school woodwork students.
I've succeeded in generating g code from my Onshape models by exporting them to fusion 360 as Rhino or Parasolid files.
It'll be a lot more convenient if my students can send me a g code file straight out of Kirimoto.
They will be doing simple logos with text in them.
I was able to generate about ten g codes using Kirimoto then it just quit playing ball. When I now attempt a slice and export there are just three or four commands in the document.
In the g code files I first made the router motor wouldn't start but I was able to put the start spindle command in the g code document and that fixed it.
I'll see if I can sort an image of the type of thing I have been experimenting with.
I created g code in Kirimoto for the one that I will show you but when I attempted to generate g code from the sale model later it just wouldn't work. Got various popups including 'no processes selected'.
