Applying Linear Pattern to inside curved surface
I'm absolutely stumped, I am trying to apply a Linear Pattern to the underside of an 3 Arch Viaduct Bridge: https://cad.onshape.com/documents/ab039effdefc81af5b5cd9c7/w/622fae194371f421edaffbdb/e/809c1cfa691fd4df8292060d , but I cannot get it to work, can anyone with experience in this area please help me overcome this issue?
mahir Member, Developers Posts: 1,315 ✭✭✭✭✭
I don't know what the intended pattern is supposed to look like, but here's one example of how it could be done. FYI I had to clean up your Main Section sketch to make it symmetrical and fully dimensioned. Otherwise, the patterns wouldn't merge properly.
https://cad.onshape.com/documents/4142e516888d1483a4e05127/w/7e390dd28118bfa6f4d91bfa/e/7cb9ece468ec420c76cdbe02
6
I have been removing some of the highlighted constraints when the sketch title appears in red.
From here on I will delete a constraint one at a time until it repairs the issue (until the Red text changes back to black), then I will undo the deletion and move onto to next constraint (stepping through systematically) until I find the conflicting constraint.
