Variable "Measure Angle" Feature Script Code001
warren_pegley
Member Posts: 14 ✭
// This is the first time I've touched this code - so a point in the right direction would be helpful, I think this script would be a helpful asset also so if there joy in punching out new features - please do.
FeatureScript 1271;
FeatureScript 1271;
import(path : "onshape/std/geometry.fs", version : "1271.0");
/** Measure the Angle between two sets of entities and set the result to a variable */
annotation { "Feature Type Name" : "Measure Angle", "Feature Name Template" : "###name = #value", "UIHint" : "NO_PREVIEW_PROVIDED" }
export const measureAngle = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "Name", "Default" : "Angle" }
definition.name is string;
annotation { "Name" : "First entities", "Filter" : EntityType.FACE || EntityType.EDGE || EntityType.VERTEX || EntityType.BODY }
definition.first is Query;
annotation { "Name" : "Second entities", "Filter" : EntityType.FACE || EntityType.EDGE || EntityType.VERTEX || EntityType.BODY }
definition.second is Query;
annotation { "Name" : "Maximum" }
definition.maximum is boolean;
if (!match(definition.name, '[a-zA-Z_][a-zA-Z_0-9]*').hasMatch)
throw regenError(ErrorStringEnum.VARIABLE_NAME_INVALID);
const angleResult is AngleResult = evAngle(context, {
"side0" : definition.first,
"side1" : definition.second,
"maximum" : definition.maximum
const p0 = angleBetween(vector1, vector2)Result.sides[0].point;
const p1 = angleBetween(vector1, vector2)Result.sides[1].point;
if (!tolerantEquals(p0, p1))
debug(context, line(p0, p1 - p0));
debug(context, line(p1, p0 - p1));
else // If it's the same point, just draw the point
debug(context, p0);
setFeatureComputedParameter(context, id, {
"name" : "value",
"value" : angleBetween(vector1, vector2)Result.angle
setVariable(context, definition.name, angleResult.angle);
https://cad.onshape.com/documents/77baa8153589a7fc5f289829/v/ceb4a03e4ac77173bf6d0074/e/181cb871f3008e6b885df46a
You may want to look into this featurescript, It can measure most of what you need and spits it out into a variable like you're doing.
At the very least you can reference this if you want to learn FS0 -
Thanks John, Great tool, down the track I'd be referencing but for now back to basics.0
