Attaching Documentation to Custom Feature
Hi,
Is there anyway we can attach additional information(Like User guide in pdf format) to the custom feature?
  • NeilCooke
    NeilCooke Posts: 6,097 image
    Hi @Kin - we use this Google Slides template for creating FS instructions, then download as PDF and upload to the first tab of the document (renaming the tab to Instructions). You can of course use your own format. It will not show when somebody uses your feature, but if they right-click and "open linked document" they will be able to see it there.
    https://docs.google.com/presentation/d/1i3SkgQDkU6agkvp3TDhOryWAhPL73LFbZ-2Y-iVnl90/edit?usp=sharing
  • Thanks Neil. I think ideal solution would be to,
    a). have the pdf attached to custom feature itself.
    b). have shortcut to the location in custom feature dialog(similar to OnShape Features).
  • lemon1324
    lemon1324 Posts: 230 EDU
    The pdf is already associated with the custom feature, just not directly. Since custom features are necessarily defined in a document, right-clicking the feature and going to the document brings you to the pdf. Unless you meant something else by attaching the pdf?
    Thank being said, I never actually noticed the help link before; would it be possible to allow FS authors to insert a similar help link directly to the PDF tab of the latest document version?
    Arul Suresh
