Improvements to Onshape - June 3rd, 2020
Well, the new holes feature has not arrived to that document so I submitted a ticket.jakeramsley said:
Hi gonzalo_chomon,gonzalo_chomon said:Thank you @NeilCooke
I think it was already active on that document but may be I am wrong.
I suppose the upgrade has still not arrived for it. Will let you know if it does not get there on the following days.
If you submit a support ticket from inside the affected document for this we can look in more detail.0 -
It will be interesting that the holes could be edited from the holes list.1
Hi guys - what is the workflow for creating this label? Any examples that you can share?romeograham said:Has anyone figured out how to apply an image as a label?
[EDIT] I see now - the label is created by splitting the face, then applying color to each face. Not applying an image (yet).
The sample in the video is an imported part. But you can do that with split face of a part
Here is the link to the Onshape document
https://cad.onshape.com/documents/53a6a83fc51fc83e218192fe/w/fbe4135f974e3cc8cf9f935a/e/9237f78345967295509892f3
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común0 -
Fantasitc improvements here! Especially coloured faces. Thank you!0
