Advanced Custom Feature like "Fill Pattern"
chris_ebert
Member Posts: 2 ✭
I am looking for some help creating a custom feature. I have an exruded rectangle. I want to put an linear array of holes with the following criteria. A hole 2" from each end. In between equally divided holes per a maximum and minimum distance. Thanks for any help regarding this quest.
Based on your description, This is something that could be done relatively easily via existing functionality (see link). Specifically, equations, linear pattern, and variables. Configurations are also a straightforward option. No featurescript needed. Is this a featurescript practice exercise? Here's how I'd do it.
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/22807b08ded8e14b3f2992df
