Rotate a Plane
ehsan_pazooki
ehsan_pazooki Member Posts: 52 ✭
Hello guys,
I want to add a new plane, to make a sketch on it. After that I want to rotate the plane together with sketch (for example for 45 degrees between XZ and XY surfaces) an then I want to use the sketch to add or remove extrude. The problem is, I don't know how to rotate the plane. I can add new planes but I don't know how to rotate them. Could someone please help me?
Best Regards
Ehsan Pazooki
