Images on Drawing Don't Appear in CorelDraw When Trying to Laser Cut a Drawing
Our students love to add images & text to their drawings that are then cut/engraved on the laser cutter. When I've added images into the Drawing (using import image) and export as a DXF or PDF, the images don't come into Corel with the rest of the vector lines .Any idea why/how can you get images from Onshape drawings into a laser-cuttable file format?
  • alnis
    alnis Member, Developers Posts: 453 EDU
    Have you tried opening the exported DXF or PDF files in another viewer application? Both export types are working for me with images. If possible, can you upload an example of one of the DXF or PDF exports that isn't working?
