Group Mate vs. Fastened
ethan_1
ethan_1 Member Posts: 17 EDU
edited November 2016 in Community Support
Does anyone notice any difference  between using a group or mate, such as performance. I personally when mating, especially repetitive things like fasteners, mate one fastener with a fastened mate, replicate it to all holes, group all together, delete the fastened maters. I find this keep things a bit cleaner.
Anyone have thoughts on this?
  • elaine_parshall594
    elaine_parshall594 Member Posts: 1
    It doesn't seem like you can achieve the kind of accuracy for center of mass calculations for an assembly by using grouping rather than mates for parts.
  • tony_459
    tony_459 Member Posts: 206 ✭✭✭
    @elaine_parshall594, Can you expand on your comment? This would be an issue---if the mass calculations were less precise just because you grouped instead of fasten parts, despite their arrangement being exactly the same. Is this just a suspicion, or did you experiment and compare results between grouped and fastened assemblies? How much error are we talking about? Thanks!
  • tony_459
    edited September 2020
    @ethan, I do the same. I'd have tens or hundreds of fastened mates in my assemblies otherwise. Plus, it's been suggested to me that groups are better for performance in very large assemblies... Not sure how true this is, but I've stuck with groups nevertheless and use them almost exclusively---unless I have a compelling reason to use a fastened mate.
  • MBartlett21
    MBartlett21 Member, OS Professional, Developers Posts: 2,064 ✭✭✭✭✭
    One bad thing about group mates is that, if you are grouping a subassembly in a top-level assembly, it stops the mates resolving in that assembly if you change them, without showing errors either.
