Meta Sculpt Surface Modeling Tool
neobobkrause
                    Member Posts: 105 EDU
                    I've developed a surface sculpting script called Meta Sculpt, which is based on the excellent Sculpt Face feature by @maximilian_schommer. Meta Sculpt allows users to sculpt a surface face by adjusting the underlying surface using point and arrow manipulators or editable/configurable field values. Multiple points are selected and deselected by clicking on them. Arrows can be used to move selected points. To keep the display simple, only arrows at the last selected point are shown, though all arrows can optionally be shown. Movement of points can snap to an optional distance quantum. Surface sculpting changes are presented as a set of "actions," where an action is the change made to a set of points. The set of points and the offsets in each dimension are editable, and support both equations and configurations. A  short documentation PDF is included in a tab of the Meta Sculpt feature document.
The screenshot below shows the top face of a cylinder being sculpted using two actions. The first action raises two selected points [0,2] up an inch. The second action lowers point [1] by 1.5 inches.
- Bob
- Bob
Looking forward to trying it out.
A good suggestion. I just made a quick change to allow actions to be reordered.
- Bob
Thank you for this update!
Is there a chance you can update this so that the sculpt by reference will work with it?
Any other feedback or suggestions based on experience using Meta Sculpt?
- Bob
As far as more feedback, it would be nice to be able to drag the manipulators in two directions at once. Similar to if you the manipulators on the transform feature.
Dragging in one direction at a time can be really time consuming. As well as sculpting without a reference.
OnShape is great, right? But one of my (many) frustrations with the tool is the dearth of FS support for direct manipulation. One of the first on my list, I would love for point and linear manipulators to get a major upgrade. The system is really held back by the lack of this type of support. (Not the least of which would be 3D sketches!) As you suggest, users should be able to simply click and drag points without being constrained by the presentation and use of arrows. But that's out of my hands at this point. Speak up if you feel similarly.
I got a little bit of time this past weekend to begin researching sculpting by reference and re-familiarizing myself with the Meta Sculpt code base. I'm thinking that the best user experience would be to toss out the separate selections of U and V splines. Instead, sculpt by reference will allow a single collection of splines and points. A point will be added at the intersection of any of the splines in the selection. Each element of the resulting point set will be manipulable.
Now all I need to do is carve out a long enough chunk of time to work out the details and code it up. It's on my to-do list, but I ask for patience.
- Bob
Thank you for taking the time to look at this Bob. The is no hurry!
