Feature script is it possible to cut and paste code between two scripts in the same work space.
ron_24
ron_24 Member Posts: 14 ✭✭
I am trying out feature script for the first time, was tripped up at the first hurdle of trying to import data from a .csv file. but leaving that aside for now, I made a copy of an existing model that had different scripts for the same model on separate tabs. I wanted to try to cut and paste code from one to the other, but the option to highlight and copy does not appear to be available. I am running Onshape within a chrome browser. Am I doing it wrong? (highlight, then either left or right mouse click), or is this operation not possible?.
  • kevin_o_toole_1
    kevin_o_toole_1 Onshape Employees, Developers, HDM Posts: 565 image
    You can use the shortcut ctrl-c (cmd-c on mac) to copy code, and then use ctrl-v (cmd-v on mac) to paste it.
  • ron_24
    Works a treat, thank you very much.
  • kevin_o_toole_1
  • ron_24
  • jeff_robbert442
    jeff_robbert442 Member Posts: 1 ✭
    Can someone elaborate on this function? ctrl-C and ctrl-V aren't doing anything for me, perhaps I am misinterpreting the intended use.
  • alnis
    alnis Member, Developers Posts: 453 EDU
    Seems to be working for me (screenkey note: Control_L is the left control key being pressed, Ctrl+c is the ctrl + c being pressed simultaneously)
