Feature script is it possible to cut and paste code between two scripts in the same work space.
ron_24
Member Posts: 14 ✭✭
I am trying out feature script for the first time, was tripped up at the first hurdle of trying to import data from a .csv file. but leaving that aside for now, I made a copy of an existing model that had different scripts for the same model on separate tabs. I wanted to try to cut and paste code from one to the other, but the option to highlight and copy does not appear to be available. I am running Onshape within a chrome browser. Am I doing it wrong? (highlight, then either left or right mouse click), or is this operation not possible?.
You can use the shortcut ctrl-c (cmd-c on mac) to copy code, and then use ctrl-v (cmd-v on mac) to paste it.1
Works a treat, thank you very much.kevin_o_toole_1 said:You can use the shortcut ctrl-c (cmd-c on mac) to copy code, and then use ctrl-v (cmd-v on mac) to paste it.0
Works a treat, thank you very much.kevin_o_toole_1 said:You can use the shortcut ctrl-c (cmd-c on mac) to copy code, and then use ctrl-v (cmd-v on mac) to paste it.0 -
Can someone elaborate on this function? ctrl-C and ctrl-V aren't doing anything for me, perhaps I am misinterpreting the intended use.0
Seems to be working for me (screenkey note: Control_L is the left control key being pressed, Ctrl+c is the ctrl + c being pressed simultaneously)
Get in touch: contact@alnis.dev | My personal site: https://alnis.dev
@alnis is my personal account. @alnis_ptc is my official PTC account.0
