How do you create an assembly in OnShape?
doug_dimmer823
Member Posts: 2 EDU
I am new to OnShape, in the create tab, I just see how to create a part. How do you take your parts and create an assembly?
More info at https://learn.onshape.com
EDIT: a document can contain multiple parts, assemblies and drawings - it is not file-based like other CADSenior Director, Technical Services, EMEA2 -
