Fluid Simulation possible?
rafescu
Member Posts: 3 ✭
Hi Onshape Community, I've got a question. Does Onshape plataform supports fluid simulation? Cause I need a sprinkler irrigator and the water flow (waterjet) is important to me... The sprinkler pieces are already done, the waterjet is the last thing...Thanks
Onshape does not have a built-in CFD module, but there are some great integrated simulation platforms. Personally, I use SimScale since it has lots of free core hours, is very easy to use, is well-integrated with Onshape, and seems to provide accurate results. Here's a sim I did for a model airplane I was working on to figure out the stall angle of the wing and estimated lift:
https://youtu.be/NzYPIAJ3qtQ
Get in touch: contact@alnis.dev | My personal site: https://alnis.dev
@alnis is my personal account. @alnis_ptc is my official PTC account.2 -
Hey @alnis_smidchens, thanks for the suggestion! I will check that
If anyone knows another module or plugin I would be aprecciated 0 -
OnShape made a Webinar with Onscale but on the Onshape website they have CFD as "add-on", but check out the OnScale ,https://onscale.com/
Here's also a webinar showing how easy it is to use Onshape with SimScale: https://www.simscale.com/webinars-workshops/design-simulation-optimization/2
