How can I make a composite part of all of the bodies I create in a feature?
monroe_weber_shirk
Member Posts: 103 EDU
I'm writing a feature script to create a ruler or a scale that includes tick marks and numbers. I want to combine all of the ticks and numbers into a single composite part at the end of the feature script.
I first tried
opCreateCompositePart(context, id, { "bodies" : qAllModifiableSolidBodies(), "closed" : false });
but that put all of the bodies in the part studio into the composite and I only want the parts created in this feature to be in the composite.
I tried creating an array of all of the bodies as I create them.
tickbodies[i] = qCreatedBy(currentID + "tick", EntityType.BODY);
and then used
opCreateCompositePart(context, id, {and then used
"bodies" : tickbodies,
"closed" : true
That fails because "bodies" is not expecting an array.
What is the elegant way of putting all of these ticks and numbers into a composite part?
NeilCooke
Moderator, Onshape Employees Posts: 5,970
Just use qCreatedBy(id) for all bodies created in the current feature.
Senior Director, Technical Services, EMEA1
