extrsion impossible
why is impossible to extrude a cylinder in the corner of a box when the base cercle is tangent to the both side ?
pourquoi est il impossible d'extruder un cylindre dans l'angle d'une boite quand le cercle de base est tangent aux deux cotés ?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 6,035 image
  • bernard_ciretbernard_ciret Member Posts: 4
    Yes is the same thing, but there is no solution !!!!
    Correct - Parasolid does not permit non-manifold geometry. You have to consider (3D printing aside) how you would manufacture it in real life? It is impossible to machine an infinitely small edge.
    n
    i drew for you a box with a circle at the bottom tangent to the both side. In this case it is impossible to extrude the cylinder.
    I know - how would you machine this part?
    Interesting - did not know this.
  • MichaelPascoeMichaelPascoe Member Posts: 2,858 PRO
    edited January 2021
    @bernard_ciret
    If you really need the cylinder in that position, extrude it as a new part.
    Or, move it slightly away from the edges so that the cylinder does not share an edge with the box.
    RENDERCAD
    Simple thanks Michael...
