extrsion impossible
bernard_ciret
Posts: 4 ✭
why is impossible to extrude a cylinder in the corner of a box when the base cercle is tangent to the both side ?
pourquoi est il impossible d'extruder un cylindre dans l'angle d'une boite quand le cercle de base est tangent aux deux cotés ?
Senior Director, Technical Services, EMEA2
Yes is the same thing, but there is no solution !!!!0
Correct - Parasolid does not permit non-manifold geometry. You have to consider (3D printing aside) how you would manufacture it in real life? It is impossible to machine an infinitely small edge.Senior Director, Technical Services, EMEA0
n
i drew for you a box with a circle at the bottom tangent to the both side. In this case it is impossible to extrude the cylinder.0
I know - how would you machine this part?Senior Director, Technical Services, EMEA0
Interesting - did not know this.0
@bernard_ciret
If you really need the cylinder in that position, extrude it as a new part.
Or, move it slightly away from the edges so that the cylinder does not share an edge with the box.
RENDERCAD
________________________________________________________________________0 -
Simple thanks Michael...0
