Reuse a previous feature to make another Part, a "lost" tool in a Boolean-Merge for example?!
christopher_owens
Member Posts: 235 ✭✭
I did locate the Loft that created my "lost" tool part used in a Boolean-Merge. What if there was a "Use" or "Recreate" option in this menu??? Then I could make a new Part using Loft 1 without a lot of hassle!
Roll back to where the body has just been created, RMB on the corresponding "Part" in the part listing, choose "Copy", click on the body to insert it into the dialog box, but don't specify any translation or rotation, and you will have an identical second body to reuse in any way you wish.
It will appear in the feature list as "Transform"; in a complex model it might pay to give it a more specific name, like "Copy for Tool" or some such.
ON EDIT
For better clarity of purpose, rather than settle for the default "translate" option, pull down the menu to choose "Copy in Place"0 -
One good thing about a history based modeller (some would say, THE good thing) is that you can go back in time.
It's not strictly necessary to think of everything you may need to do in future with the model, because you have "rollback" which is, essentially, Time Travel.0 -
@andrew_troup Actually the "Copy Sketch" comes in handy! I can create a new part out of copied sketches with are now independent from the originals! Thought about that at lunch!0
You might in some instances do better with Use/Project, rather than Copy. I hope in future that we will be able to emulate the "Derived" sketch of Solidworks, in order to make a live copy of a sketch (one which updates along with the original)0
@andrew_troup Yes I can reuse that part, unless I want to "resize" it. Then that also changes the original "lost" tool and it's Boolean. Coping the sketches creates a fully new part. I think for a loft that takes some tweaking to get to work this would be very handy! Copy the profiles and guide curves so they are close but maybe you want to vary the guide curve.0
