Is Onshape able to animate my assembly?
vince_long
vince_long Member Posts: 9 ✭✭
I have two revolute mates on 2 parts and a tangent mate between the sliding faces which is a cam and lever type set up. The revolute mates work fine until I create the tangent mate. Also on the same assembly there is a similar effect between a rotating gear and a rotating gear tooth which is also connected to the lever. I would like to rotate the gear and have the tooth and lever move accordingly if this is possible.
File link is L&M Centre Pin 1 - Copy 2 | back plate / spigot assy (onshape.com)
Thanks
