Regarding edit logic function
konstantin_shiriazdanov
edited March 2021 in FeatureScript
There is a feature which imports some part studio bodies with attributes by means of instantiator and depending on attribute values it is desireble to switch feature definition to some state. I cannot resolve the attribute query inside edit logic function because I beleve the entities don't exist in context yet. And I do not want to perform import inside edit logic to just get some attribute flag, I'm not sure if it is even possible, but anyway it would be too time consuming. So the question is: is there any approach to interact with edit logic function (or widely - with definition state) from inside of the feature function thread? Im my case I just want the attribute value of imported entity to affest some enum value of definition.
  • caden_armstrong2
    caden_armstrong2 Member, User Group Leader Posts: 121 ✭✭✭
    Are you trying to pass information from the main feature thread back into the editing logic function?
    You can only go from editing logic -> main feature, not the other way around.
  • caden_armstrong2
