Translate and Pour
a_godfreya_godfrey Member Posts: 3
Trying to get this assembly to translate in the x-direction as the decanter assembly rotates 180 degrees.  It looks like a rack and pinion motion but I can't get it to work.
https://cad.onshape.com/documents/ac0b5179e84e80d2a2728d22/w/8e78e7dcae44d7df510b807e/e/e44e30c934f7662e118be2c7
  • MichaelPascoeMichaelPascoe Member Posts: 2,821 PRO
    edited April 2021
    @a_godfrey
    Here is one method you could use to do this:
    https://cad.onshape.com/documents/54d6f58602fbb00c74113fb8/w/7f73d8140b61da0847f59115/e/389c59077c34ff219803e592
    • Ungroup the needle from the MRV
    • Create a slider mate between the Needle and part 1
    • Create a revolute mate from the MRV group to the Needle, set your limits here
    • Add a Rack and pinion relation between the slider and the revolute mate
    • If you want to animate the mates, right click the revolute mate and selecte "Animate"
    RENDERCAD
  • a_godfreya_godfrey Member Posts: 3
    Thanks for these tips - very helpful!  The needle even travels with the decanter without rotating which is what I wanted but it's 180 degrees from where I had intended it.  Still wrapping my head around some of the mate relationships, but I did figure out that I had to remove Mate connector 3 to be able to make the rotation and then reapply the mate.
