How do I auto-focus first parameter of array?
George_Anderson
Member Posts: 71 ✭✭
I have an array parameter, where each has an "entities" parameter. When the user clicks "Add" to add a new array item, I want the "entities" field to be auto-selected. I'm trying to use the UIHints for auto-focus, but it doesn't work yet.
Here's an example:
Any ideas?0
The "FOCUS_INNER_QUERY" only works for a selection-driven array parameter (AKA one with "Driven query" set to that query parameter). Selection-driven array parameters add items by making selections while the outer array is focused. Seems like this switch might work for your workflow, and save a button click.
"FOCUS_INNER_QUERY" does not work on arrays that are not selection-driven, though you could submit an improvement request to suggest it!
@kevin_o_toole_1 Thanks for the clarification about "FOCUS_INNER_QUERY". Unfortunately my real use case doesn't work with selection-driven parameters. Each "operation" accepts a variable number of entities. (So the first might take 1 body, the second 3 bodies, etc.).I'll submit an improvement request.0
Posted improvement request here: https://forum.onshape.com/discussion/15945/auto-focus-first-sub-parameter-after-adding-array-item/p1?new=1
It's also weird because the FOCUS_INNER_QUERY description in the documentation isn't very clear - it's currently the only place documentation where the term "QLV" is used. INITIAL_FOCUS_ON_EDIT and INITIAL_FOCUS also don't explicitly say they don't work with internal array parameters, although this is likely because their descriptions were written before array parameters were added to FeatureScript.Software Developer at Epic Systems
FRC Design Mentor - Team 1306 BadgerBots0
