How to draw/extrude a 45 degree locking miter.
I can create miter corners easy enough, but I want to include the zigzag that this miter bit creates... https://smile.amazon.com/Meihejia-Degree-Router-Woodworking-Cutter-Tool/dp/B07BJHZKHQ/ref=sr_1_29?dchild=1&keywords=router+bit&qid=1618344223&sr=8-29
[center][/center]
  • bruce_williams
    bruce_williams Member, Developers Posts: 842 EDU
    Here is an example document.
    And steps:
    Create profile from image (I did not dimension to size)
    Make frame and add mate connector on corner to copy sketch on
    Copy the profile sketch on mate connector
    Extrude surface to use as split tool
    Split and make assembly
    www.accuratepattern.com
