Improvements to Onshape - April 19th, 2021
2»
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,944 PRO
    My space mouse seems to be more responsive in drawings now. No doubt this is due to all of these awesome updates.
    RENDERCAD
  • tim_hess427
    tim_hess427 Member Posts: 648 ✭✭✭✭
    @ryan_mcgoldrick - We had a similar problem and ended up using the 'description' field as a stand-along part name field.
    So, the document, part studio, and part name might all be something like "PRT-10015 Axle Spacer" and then the description for the part is just "Axle Spacer".  Then, in our BOMs, we just have a "description" column and take out the "name" column. This means our descriptions aren't long and aren't as useful, and the occasional typo will trip us up causing things to not match, but in general, this has been working OK.
    Ideally - It would be awesome to extend the ideas from "export rules" to apply to the parts lists in part studios and assemblies (ie. create "display name rules"). Then, we could keep the right information in the right place.
  • gareth_farrington
    gareth_farrington Member Posts: 15 PRO
    Thank you for the "Surfacing Tips and Best Practices"! I never understood the pierce constraint and now I do. There are a lot of situations where Loft has been frustrating to use and I am now excited to try Fill Surface instead.
